It is currently Thu Jul 02, 2026 1:28 pm
 Post subject: 4G63 Turbo Engine Swap
PostPosted: Sat Jan 31, 2009 3:30 am
here is a cool write up done on a dodge d-50 200hp turbo stock, was told easy to get 350hp with out going inside the motor for around $600 to $1200 in mods..dont know if its true or not ( maybe Luvrv8 can chime in on that) anyway here you go for all the people that ask what would work in the luv...
http://www.hotrodcoffeeshop.com/forum/viewtopic.php?t=3
PostPosted: Sat Jan 31, 2009 9:16 am
Very detailed write up on that conversion and could be done in a LUV as well. Good find there ctmandu.
PostPosted: Sat Jan 31, 2009 10:32 am
Thanks, found this info when i was searching for engine swap for a 72 Celica... may just have to try it to the SST, i would like to freshen it up and may repaint it
