It is currently Wed Jul 01, 2026 5:30 pm
Post new topic Reply to topic  [ 27 posts ]  Go to page 1, 2  Next
 Post subject: 4.3l v6 headers help
PostPosted: Thu Feb 21, 2008 5:48 pm
i cant seem to find headers that are a lot of $$$.
if you know of some cheap headers let me know . :ebiggrin
 Post subject: Re: 4.3l v6 headers help
PostPosted: Thu Feb 21, 2008 8:38 pm
http://store.summitracing.com/partdetai ... 4294907043
I dunno what alot of money is....I dont have any
PostPosted: Thu Feb 21, 2008 8:50 pm
i been looking at summits headers thare the cheepst.
but will thay fit a chevy luv? lol with a 4.3
PostPosted: Thu Feb 21, 2008 9:58 pm
Most likely no.
Most likely you will need to do some fab work.... some hammering, some cutting and some welding and a lot of time and patience.
PostPosted: Fri Feb 22, 2008 11:22 am
im willing to do fab work.
PostPosted: Mon Mar 17, 2008 2:59 pm
Try Sanderson out in CA. They make headers for pretty much anything.
PostPosted: Mon Mar 17, 2008 3:41 pm
i got some headman headers for a 4X2 s10. ill let you know how thay fit. :chain:
PostPosted: Tue Mar 18, 2008 3:14 pm
just curious, what headers do most people use for a SBC? If you have to use some sort of block hugger header for the V8 you would have to use it for the 4.3 as well. Width wise the motor are supposed to be the same so you would have the same issues with either motor.
PostPosted: Tue Mar 18, 2008 8:35 pm
block huggers are what i used on my V8 luv . i miss it to.
on the 4.3 thay are the same Width.
PostPosted: Fri Mar 21, 2008 8:32 pm
I just pulled a 4.3 out of a 1992 GMC Jimmy and am getting ready to atempt an install.
Can you give any advice on it?
How did those headers work?
PostPosted: Mon Dec 08, 2008 5:28 pm
RickT the headers are out of a s10 thay fit good with some mods.
the year of your luv will make a diffrents mys a 74 .
PostPosted: Tue Dec 09, 2008 11:40 am
What transmission did you use and what all modifications did you have to do? What mounts any help would be great as I am thinking of doing the swap soon.
PostPosted: Tue Dec 09, 2008 12:10 pm
the transmission is out of a chevy monza its a 5speed
the transmission mount is a chevy comaro 1980 i think is the year. and a stock chevy luv transmission mount
the moter mounts are a 1969 chevy c10 pickup.
the newer the luv is the better it be to do it in. it looks like it just a bout bolt in to the 1980 luv. but my luv is a 74 ant the frame is just a little diffrent.
PostPosted: Tue Dec 09, 2008 1:49 pm
I have a 78 LUV. I am kinda confused about the pics of your mounts, is there bars to move them or something. What headers excatly did you use.
PostPosted: Tue Dec 09, 2008 1:53 pm
http://store.summitracing.com/partdetai ... toview=sku
PostPosted: Tue Dec 09, 2008 2:05 pm
the bars are just a adpters i made for the moter mounts.
your 78 will not need the bars. your moter mounts are back more than my 74luv are.
PostPosted: Tue Dec 09, 2008 5:42 pm
Cool thanks for the info I will stay in touch, Did you get your running?
PostPosted: Tue Dec 09, 2008 7:29 pm
not yet been slacking. :econfused the last pic i have of it .
PostPosted: Tue Dec 09, 2008 7:40 pm
looks good what starter did you use? How low do the headers hang? I have the engine just need to rebuild it. Now I need to find the trans and ill be good. What about the driveshaft?
PostPosted: Tue Dec 09, 2008 7:57 pm
the starter is a stock s10 starter.
the driveshaft is on my to do list. im going to run the stock rearend .
