It is currently Thu Jul 02, 2026 4:21 pm
 Post subject: what cam?
PostPosted: Mon Oct 13, 2008 12:11 pm
i want to have delta cams hook me up with a cam. i want to be able to tell the truck is cammed. what cam grind do u guys like?
 Post subject: Re: what cam?
PostPosted: Wed Oct 15, 2008 8:00 pm
I think they do only one grind for the 1.8l motor
PostPosted: Thu Oct 23, 2008 4:07 pm
They have 260 270 and 280 I think...
The 260 is pretty mild along with the 270.
If you go 280 it will probably lope, but your gonna have to do other mods like porting, header and better induction compression etc. for it to run right.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Sun Feb 15, 2009 11:29 am
its got 32/36 weber ( i want bigger) and header with 2,1/4 piping.i called delta and they said they could do a 292 or bigger but bigger would require other head mods. i have a g200 with oversized pistons and shaved head, im thinking about swapping that in and cammin it
