It is currently Tue Jun 30, 2026 6:52 am
 Post subject: The new motor~
PostPosted: Tue Sep 30, 2008 11:41 pm
My new (semi new) 383 motor for my luv! Gotta replace my old tired 305 :D
I had a nice little speech typed up @ work... then the little filter thing deleted it all ><
Its a 350 block, 4 bolt mains, Scat 400 crank, 10:1 compression, RPM performer intake, edlebrock 650CFM carb, dart 202 angle plug cast iron heads, 1.6 roller rockers
Image Image Image Image
 Post subject: Re: The new motor~
PostPosted: Tue Sep 30, 2008 11:42 pm
Image Image Image
PostPosted: Wed Oct 01, 2008 5:50 pm
when I built my first 350 for my luv I painted it yellow too. I thought it was a pretty good idea at the time , but soon came to realize that yellow is VERY hard to keep clean. So when I put the caddy in I painted it that "jet" or "flat" black, but still shows the oil. That'd be nice to have a color that doesn't show the dirt and grime. Looks good tho!
1975 LUV with a caddy 500ci, 12.5-1 comp, 850CFM holley sucking E85 through 110 jets and torquing the hell out of a TH400. Currently @ 6mpg
Bowties may be for little boys, but ponies are DEFINATLY for little girls....
