It is currently Mon Jun 29, 2026 3:38 am
PostPosted: Fri Aug 01, 2008 7:35 pm
I want to hook the 2.2 Isuzu diesel up to my 80 4x4 tranny. If it wont bolt up could the bell housing be modified or is there an adapter plate. I have good mechanical skills and am handy with a mig and arc welder. Just wanting to know how big this project will be before i jump in over my head. Thanks in advance for all of your help. Jeremy
PostPosted: Fri Aug 01, 2008 7:51 pm
Australian LUV Guru
The diesel engine wont bolt up to the gasser tranny, starter on opposite side, bolt up pattern different etc. 1 option you have is to source bellhousing(front caseing) from a diesel and do the swap.
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Tue Aug 05, 2008 3:33 am
Is the bellhousing section removable or does a guy have to swap tranny guts from one case to the other?
PostPosted: Wed Aug 06, 2008 9:22 am
Better back up and think this through. The diesel 5-speed bellhousing will fit the gas 5-speed transmissions, but NOT the 4-speeds (gas or diesel). I don't believe the diesel 4-speed 4wd bell housing is removable, but maybe someone else can shed some light on that question.
PostPosted: Wed Aug 06, 2008 12:36 pm
Thanks, Jack!
PostPosted: Wed Aug 06, 2008 10:29 pm
Hey if you want I have the four speed trans out of an '82 chevy luv 4x4 and it was bolted to the diesel. Although I have long since taken the diesel out and put it in my '80 luv 2wd but the trans remains. Give me an e-mail if you want to consider this as an option. I am sure that it would make your conversion process a whole lot smoother. My email is truckerforlife@hotmail.com
PostPosted: Thu Aug 07, 2008 4:31 am
Australian LUV Guru
The swapping of bell housings(front caseing) from gas to diesel on a 4wd trans is done, just the same as you would do on a 2wd trans.
PostPosted: Sun Aug 10, 2008 10:29 am
And it will not matter if it is a 4 speed or a 5 speed box as the 5th gear stuff is located behind the 'sandwich' plate.
It does not matter if the box is a 4 or a 5 speed as again this is behind the bearing carrier plate that the front housing bolts to.
Thats not to say there might not be some differences but as yet i have not found one and i have swapped a few over.
Bob.
