It is currently Sun Jun 28, 2026 12:11 am
PostPosted: Sun Jun 29, 2008 11:37 pm
If anyone out there has done a motor swap and cleanly cut the motor frame mounts from a 76-80 Luv, I'll pay you for them. I'm putting a '79 motor in my '75 and need the second generation mounts. The cut from the frame needs to be clean. A sawsall cut or a tight torch job would be fine. I'd like pictures if possible. If you got mounts, let me know.
Khy in Austin
If anyone out there has done a motor swap and cleanly cut the motor mounts from a 76-80 Luv, I'll pay you for them. I'm putting a '79 motor in my '75 and need the second generation mounts. The cut from the frame needs to be clean. A sawsall cut or a tight torch job would be fine. I'd like pictures if possible. If you got mounts, let me know.
Khy in Austin
