It is currently Fri Jun 26, 2026 9:48 am
 Post subject: radiator selection?
PostPosted: Fri Jun 06, 2008 7:00 pm
what radiator is the most common for a v8 swap?
 Post subject: Re: radiator selection?
PostPosted: Fri Jun 06, 2008 10:20 pm
Have you seen this? http://www.luvtruck.com/pdf/12606.pdf
The Howe number has changed, but I want to say it's a 22" x 19" unit. Correct me if I'm wrong folks...
Still haven't bought mine, I'd be interested in what you end up with. There is a seller on ebay with Griffin seconds that should fit this application also...
PostPosted: Fri Jun 06, 2008 10:26 pm
I installed my motor and them fitted the largest one I could cram in there.
PostPosted: Sat Jun 07, 2008 3:28 am
When possible a 3 core is better than a 2 core. Makes a bigger difference than an inch or two of increased dimensions.
PostPosted: Sat Jun 07, 2008 10:48 am
Your going to need a 4 core for the V8. However, Griffen has an aluminum 2 core that is equivalent to a traditional 4 core.
PostPosted: Sat Jun 21, 2008 10:28 am
From what i've read, they say all Aftermarket aluminum 2 core's are equivalent to a traditional 4 core. Go with the aluminum.
