It is currently Wed Jun 24, 2026 5:11 pm
 Post subject: Little hesitation
PostPosted: Fri Jun 06, 2008 12:21 am
I have a little hesitation while trying to start off. :? After that it runs awesome! :
What is the problem? 8O
I LUV my 76!
I hate my RUST! Image
 Post subject: Re: Little hesitation
PostPosted: Fri Jun 06, 2008 4:27 am
Rick,
Same problem with our holley too. If you find a cure let us know
because 3 other drag racers are just as perplexed!
Mr.T
PostPosted: Fri Jun 06, 2008 4:45 am
Australian LUV Guru
mr.T wrote:
Rick,
Mr.T
On some Holley carbs they use a little plastic cam that the accelerater pump arm rides on, you may need to change this cam as it may be giving to much or to little squirt of gas as you start of. :idea:
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Mon Jun 09, 2008 2:21 pm
Rick,
Solved our problem! Going up with our shooters did not cure the hesitation. We installed a 50cc pump housing with our orginal white cam and shooter on the secondaries. Launched great all day.
Mr.T
