It is currently Wed Jun 24, 2026 6:40 pm
 Post subject: mine vibrates
PostPosted: Fri May 23, 2008 12:59 am
my 76 Chevy shakes and vibrates while going down the road. lots worse when reaching 45 mph or more. any advice?
I LUV my 76!
I hate my RUST! Image
 Post subject: Re: mine vibrates
PostPosted: Fri May 23, 2008 7:42 am
Are the tires balanced?
'78 1.8L 4-speed Fleetside
Image Image
PostPosted: Fri May 23, 2008 8:38 am
Tire balance, loose parts in the front end, perhaps a driveline issue.
I'm with fullaluv, sounds most like tire balance to me. If it started suddenly it could be you lost a wheel weight or someone knocked one off for you. It could also be a tire about to separate. I just had one do it to me and it starting vibrating for about a week before just letting go. If it has been going for a while then you could have alignment issues wearing the tires uneven and creating out of balance problems. Either way, easiest to just take it to a tire shop and have them balance the tires. Usually if you go to a shop that sells the brand of tires you have on you can get them to do it for free.
To check out the front end, have someone wiggle the steering wheel back and forth and crawl under and see where things are moving with slack. Also jack up each front wheel and try to wiggle it. Top to bottom and then side to side. If it moves/knocks both ways it is likely wheel bearings, if it just moves top to bottom it is likely a ball joint. If it just goes a little side to side it would be in the steering linkage somewhere. Worst wear point on these is the idler arm bushing, its the thing on the passenger frame rail in the same position as the steering gearbox is on the drivers side.
The driveline is a bit tougher to diagnose. Crawl under and try to wiggle it around. There shouldn't be any slop in the u-joints or at the rear axle. If it is bent or out of balance it is really hard to check in the driveway. You'd have to find a driveline shop.
PostPosted: Tue May 27, 2008 10:33 am
I bought 4 new tires and it solved my problem! 8) WOW! I really like my truck a lot better now! :D Got a new windshield paid for and will be installed tomorrow. $165.00
I LUV my 76!
PostPosted: Tue May 27, 2008 11:12 am
:smt041
Image Image
Users browsing this forum: No registered users and 59 guests
