It is currently Thu Jun 25, 2026 2:54 am
 Post subject: disc brakes
PostPosted: Thu May 08, 2008 12:37 am
hi there anyone in australia got some front discs they wont to sell need for my 1973 luv for brake upgrade?
 Post subject: Re: disc brakes
PostPosted: Thu May 08, 2008 4:10 am
Australian LUV Guru
Where are you located mick13bt ?
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Thu May 15, 2008 8:03 pm
Real easy to get.
If your more than 5 mins away from a set i would be surprised.
Definately not worth posting/sending.
Grab the front stub axles/brakes off any 2wd KB series Rodeo. 84 or 85 is when they started with ventilated discs on the front, id go for them and not worry about the solid discs.
The Brakes on the Holden Shuttle bus look the same as the Rodeo but i havent fully checked them out yet to be sure the stub axle is the same.
While your at it get the diff out of the same Rodeo. Swap it in and you will have a hand brake that works properly.
Bob.
