It is currently Fri Jun 26, 2026 9:05 am
 Post subject: T-5 Tranny
PostPosted: Thu Apr 03, 2008 10:54 am
Does any one know if a GM T-5, out of a S-10 or Astro van, bolt up to an Isuzu 1.8?
Thanx in advance
Dano
Garage is empty;
Between trucks
 Post subject: Re: T-5 Tranny
PostPosted: Mon Apr 14, 2008 5:56 am
I think you need one from behind a 2.6L in a pup.
Im going on what i heard. Some of them had T-5 boxes. The rest had an MUA box. They are pretty strong and come std with a remote mounted shifter. Puts the gearsitck about 6" further back.
I would go the MUA box. They are the same all round except they have a larger output shaft and are a bit fatter in the belly.
You will need an hydraulic clutch to fit the box.
Bob.
