It is currently Fri Jun 26, 2026 4:12 am
 Post subject: brake upgrade
PostPosted: Fri Mar 28, 2008 7:37 pm
hi all im in australia i currently own 1973 chev luv im chasing front disc brake set up i already have disc brake booster can anyone help so i can find some? does anyone no much about this conversion? cheers
 Post subject: Re: brake upgrade
PostPosted: Fri Mar 28, 2008 8:55 pm
If it is stock disc brakes you want just find a 78 or up Luv that has them. Complete bolt on swap
PostPosted: Fri Mar 28, 2008 9:13 pm
Australian LUV Guru
The discs,calipers and stub axels out of 81 Holden Rodeo's and early Holden Jackaroo,s are a bolt swap. Ive done a upgrade that uses vented Jackaroo rotors.
1980 4x4 KBD40 ISUZU/Chev Luv
