It is currently Tue May 26, 2026 12:04 am
 Post subject: V6 out of a '96 Camaro?
PostPosted: Sun Nov 25, 2007 8:48 pm
Would it bolt up to my tranny? And if not, would the tranny out of that bolt up to my transfer case?
I have a '80 4x4 btw.
Thanks guys.
PostPosted: Sun Nov 25, 2007 11:09 pm
You need to roll around on your back and look at the bottom of your truck.
Your trans. and transfer case are one piece, if your truck is stock.
I don't think that V6 would bolt up to your tans. and the Camaro's trans. does not have a transfer case if it is stock. :D
That Camaro eng. and trans would be nice in a 2WD truck though.
PostPosted: Mon Nov 26, 2007 2:10 pm
Banishment Pending
no...it won't bolt up...the only engine that will bolt up to that tranny is an Isuzu engine...now with that said what some of the Trooper guys that have the 2.8 Chevy V6 do is swap out the 2.8 for a Camaro 3.4...You could do this in your Luv, but you'll need a MUA-5 out of a 2.8 powered Trooper as it has the Chevy 60* bolt pattern. for more info on this (it's been gone over many times) do a search for 3.4 swap here, another place to find info would be the Isuzu section of http://www.4x4wire.com...again do a search and you'll find a ton of info
