It is currently Mon May 25, 2026 3:41 am
PostPosted: Sun Sep 16, 2007 8:23 pm
hey everyone i got an issue with my motor when i try an start it. it turns on and runs but it diesels.(when the motor shuts off it trys to turn backwards). i think it is because the cam isn't degreed right or a huge vacum leak but any suggestions that would make a motor do that
PostPosted: Sun Sep 16, 2007 8:42 pm
Make sure the distributor is installed correctly, then go from there. Not really enough info at this time to be able to narrow it down. Good luck.
PostPosted: Mon Sep 17, 2007 7:49 pm
yes the distributer is in correctly the motor runs but idle wont go lower than 1300 if it does it dies istantly. When it dies the motor spins backwards.
PostPosted: Mon Sep 17, 2007 8:09 pm
what do you have for a carb on that thing?
72 luv v-8 owned since 16!
240" rear engine dragster
[color=#FF8000]
29 dodge 4 dr sedan (project)
PostPosted: Tue Sep 18, 2007 5:04 am
you cant set the timing at 1300 RPM.
You need to go back to timing marks and degree wheels. Better to be safe than bent valve sorry.
Bob.
PostPosted: Wed Sep 19, 2007 9:29 am
Do you have one of those crank sprokets that you can set 10 +/-? Another half way effective method of timing if just turn your dizzy until it idles at its highest (not about 1100 or so). That SHOULD (well, at least on my mild street engine) be about 16 or so.
I also had something funky like that on a 302 in an A once, the msd mag pickup was bad
1975 LUV with a caddy 500ci, 12.5-1 comp, 850CFM holley sucking E85 through 110 jets and torquing the hell out of a TH400. Currently @ 6mpg
Bowties may be for little boys, but ponies are DEFINATLY for little girls....
PostPosted: Wed Sep 19, 2007 10:00 am
also, if you have a vaccuum leak, it can do that. i had a 2 bbl carb on a 4bbl int. with a adapter plate once. the carb hung over the adapter plate a little, and it had a bad vaccuum leak. it idled really high, and deisled when i tried to shut it down. wouldnt run below 1200 rpm... so check for leaks cause that kindof sounds like what i had going on. could be a hose not connected or split. could be carb gasket or intake gasket... hope ya get it settled, that stuff can be a pain..
PostPosted: Wed Sep 19, 2007 10:02 am
Hey, just thought about it... if your rocker arms are adjusted too tight, it will act like that, too.
PostPosted: Wed Sep 19, 2007 4:30 pm
thanks for all the help guys alot off stuff here that is helping trouble shoot this issue thanks. anymore info on issues like this will help to
