It is currently Mon May 25, 2026 7:26 am
 Post subject: Cheap Hooker Headers
PostPosted: Fri Oct 12, 2007 6:29 pm
Is Jegs the cheapest on the 2140 supercomp headers for the v8 swap? Looks like 419 in jegs and 650 in summit. Anyone know where to get um cheaper?
 Post subject: cheapest NOT supercomp
PostPosted: Sat Oct 13, 2007 10:57 pm
Regular block huggers are real cheap and fit fine. Won't flow as well though.
PostPosted: Sun Oct 14, 2007 6:41 am
Block huggers have a odd exhaust dump on one side if I remember correctly and a very close/tight fit. Someone on here just finished up installing a set.
PostPosted: Sun Oct 14, 2007 2:53 pm
get the hooker header and then get a set of heddman "S" sections, then you can flip'em over and run your exhaust between your body and frame
1975 LUV with a caddy 500ci, 12.5-1 comp, 850CFM holley sucking E85 through 110 jets and torquing the hell out of a TH400. Currently @ 6mpg
Bowties may be for little boys, but ponies are DEFINATLY for little girls....
PostPosted: Sun Oct 14, 2007 3:59 pm
What's this? Hooker headers for what application? Do you cut the collector off and install the S? Got pics of one that's been done this way?
 Post subject: headers
PostPosted: Tue Oct 16, 2007 3:26 pm
so will the regular block hugger headers work on a 78 luv?
PostPosted: Tue Oct 16, 2007 4:55 pm
like this or some other way???
'79 luv near stock
'80 luv "sold to another luv owner"
PostPosted: Tue Oct 16, 2007 7:31 pm
I wouldnt have room for my radiator that way
PostPosted: Wed Oct 24, 2007 7:22 am
Now that is a clean install and the radiator can be mounted in the bed where you can use a BIG one for better cooling,It's been done more than once so it will work and the weight is where it belongs.
PostPosted: Wed Oct 24, 2007 7:25 am
:twisted: Just looked at that header and the room ,can you say BIG turbo?
PostPosted: Wed Oct 24, 2007 1:52 pm
now THAT is a slick setup, might be a little noisy up front tho, lol.
