It is currently Sun Jun 28, 2026 12:11 am
 Post subject: header swap
PostPosted: Wed Jun 27, 2007 8:02 am
Location: Colonial Beach VA. If i am not home or at the track then I am probably at HOOTERS!
Has anyone on here tried a set of fenderwell headers for an s-10 on their luv I have posted needing a nice set of hookers in the classifieds for some time with no luck one of my race tracks is getting tough on not having some sort of muffler. So if the fenderwells will work I can make exhaust
74 LUV 355 Bracket Car
WANTED DEAD OR ALIVE 68-74 NOVAS
TOO MUCH IS NOT ENOUGH!!!!!!!!!!!!!!
PostPosted: Wed Jun 27, 2007 9:09 am
Check it out. http://forums.luvtruck.com/viewtopic.ph ... 94&start=0
PostPosted: Wed Jun 27, 2007 9:48 pm
Japanese Redneck
it really depends on how your motor is mounted. I used the hooker V8 Conversion motor mount kit years ago and got by with block huggers but when i decided to step up the motor program i used the S-10 Hedman fenderwell headers 2" primary I had to modify one of the tubes on both sides a little to fit my truck whereas somebody else on here was able to make the 1 7/8" heddmans fit just fine.
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
