It is currently Tue Mar 26, 2019 3:54 am
Post new topic Reply to topic  [ 137 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7
PostPosted: Sat Sep 10, 2011 12:09 am
There's no mention of transmission gear ratios in this thread.
Has anyone got a gear ratio chart, comparing the LUV 4-speed to the Pup 5-speed?
Also, a little Off-Topic, but since the subject has come up in this thread...do the Isuzu "Z" series engines interchange with the "G" series engines...in terms of the motor mounts? will a 2.3 or 2.6 bolt into my '75 LUV?
PostPosted: Mon Jan 09, 2012 10:27 am
so you can literally swap parts from an GM which is the equivalent of any Isuzu? All but rebadge Chevy from Isuzu itself.
"love your luv truck"
PostPosted: Sun Feb 12, 2012 8:46 pm
Have a question about all the 5-speed swapping. I have a 79 longbed with stock 1.8 4-speed setup. Also have a 5-speed from an 88 or 89 P'up that was a 2.3, so the cable setup was the same. The input shaft has more splines than the LUV 4-speed. Is there a clutch kit I can buy to make this work, or do I need an older 5-speed?
PostPosted: Tue Apr 03, 2012 10:26 pm
Will the stock speedo work with the 5 speed from the 4 speed or do I need to calibrate it
PostPosted: Wed Apr 04, 2012 7:02 am
No. Yes. That all depends on what the 5-speed came from, and what you're driving.
PostPosted: Fri Apr 06, 2012 9:41 pm
Used my gps on the phone and the speedo is dead on thanks still looking for a new to me for a speedo 76 luv oval style
PostPosted: Thu Nov 01, 2012 11:05 am
From what I read here so far the easiest drivetrain swap for a 76 LUV would be anything before 87?
If I had an 89 Pickup would I be able to transplant the entire drive train? (My 76 has a seized engine and the tranny was close to dead too)
Can I use the 89 Pickup 4 cyl. engine with the same motor mounts already in my 76 LUV?
I understand the Pickup drive line will have to be shortened since it's coming out of a long bed PUP and my LUV is short bed.
Then I would use the LUV's rear leaves for the Pickup rear axle?
Would I also need to take the Pickup's master cylinder?
PostPosted: Thu Nov 01, 2012 3:26 pm
elruffian wrote:
If I had an 89 PUP...
IF you had one, you'd have the ONLY one. There were no PUPs after '87.
PostPosted: Thu Nov 01, 2012 4:27 pm
Right, 89 Pickup, let me edit that lol.
PostPosted: Wed Dec 12, 2012 10:00 pm
i have seen a chart, will look for it again but the 1-4th are the same and the 5th is .855 so 14.5% overdrive
PostPosted: Wed Dec 12, 2012 10:18 pm
Gas
1ST 3.431
2ND 1.969
3RD 1.364
4TH 1.000
5TH .855
PostPosted: Wed Dec 12, 2012 10:40 pm
love4theluv wrote:
Gas
1ST 3.431
2ND 1.969
3RD 1.364
4TH 1.000
5TH .855
Here's some more, from that thread...
Code:
       Gas      Turbo DSL     NON-Turbo DSL   Turbo Impulse
1ST   3.431       3.785          4.122            3.431
2ND   1.969       2.171          2.493            1.963
3RD   1.364       1.413          1.504            1.364
4TH   1.000       1.000          1.000            1.000
5TH    .855        .855           .855             .755
I _believe_ the column labeled as "Gas" refers to the transmissions AFTER 1986, but I'm not certain. I do know that there were MAJOR changes in the '86 and later MSG-5 transmissions including a different countershaft ratio, which would affect 1st, 2nd, 3rd, and 5th gear ratios. If someone needs it, I can look at my shop manual and see what it says for the 1983 gas and diesel P'up, and it should be the same for all 1981-1985 transmissions. But I always try to discourage people from using the 1981-1985 transmissions because they were pretty failure-prone. That's why they were modified in 1986. The '86-up transmission is much stronger.
PostPosted: Mon Mar 18, 2013 3:21 pm
does somebody have for sale a slip front joke for a isuzu 86 i just need this part to make my truck run if someone have it please call me 707 376 5450 thanks
PostPosted: Mon Mar 18, 2013 6:21 pm
Yup.
Just posted this a few days ago...
viewtopic.php?f=8&t=27246&p=198823#p198823
PostPosted: Fri Mar 22, 2013 2:25 pm
Shipped this out Tuesday night, and he's driving it today!
PostPosted: Wed Jan 15, 2014 7:16 pm
hi i am new to this forum, i have an 83 chevy s10 with the isuzu 1.9 gas engine and am looking to convert from four to five speed trans. i have been told any isuzu 5 speed will work however am not sure i want to use a newer five speed from possibly an hombre or another s10 that has the newer 2.2 gas engine as i have been told that gm rebranded it as theirs yet it is actually an isuzu engine (hear say not fact) i love my trucks gas milege however it is a bit gearbound at highway speed and would like to have that fifth gear.. being you guys were talking about isuzu i figured you may have some useful info that could help me or maybe know where to get it...any info would be greatly appreciated...thanks...tom
PostPosted: Thu Jan 16, 2014 7:49 am
Tom,
Someone here may already know, but I don't. So let's figure out what transmission is in your truck now. I know the diesels had a Borg Warner transmission that was the same as other Chevy/GM vehicles. If yours has that, forget the Isuzu transmissions and get a T-5. If it has the Isuzu transmission, it will have at least an Isuzu logo somewhere on the housing. Can you check?
