It is currently Sun Jun 28, 2026 6:35 pm
 Post subject: oil pan
PostPosted: Tue Jun 05, 2007 4:40 am
Does anyone know the part number of the z28 oil pan the you need to run for the v8 swap??? or can you just use a stock oil pan???
PostPosted: Tue Jun 05, 2007 5:21 am
I haven't used any certain type of pan. I've got an 8 quart Moroso on mine now, so I believe any stock pan will fit.
PostPosted: Wed Jun 06, 2007 8:56 pm
mine is stock
1977 Chevy Luv
350/TH350
PostPosted: Mon Jun 11, 2007 12:15 pm
mine is a moroso 8 qt hamberger pan and no problem. anyone will do fine if u ask me.
http://bonsaint.com/luvalbum2/index.htm
more pics of my 76 406ci 4 spd posi.
PostPosted: Thu Jun 14, 2007 5:41 pm
Location: Colonial Beach VA. If i am not home or at the track then I am probably at HOOTERS!
i have a stock on mine I tried to use a moroso 7 quart but where it bulged out on the sides it hit my headers
74 LUV 355 Bracket Car
WANTED DEAD OR ALIVE 68-74 NOVAS
TOO MUCH IS NOT ENOUGH!!!!!!!!!!!!!!
PostPosted: Thu Jun 14, 2007 6:24 pm
I have a stock oil pan as well.
PostPosted: Thu Jun 14, 2007 6:27 pm
When I got my 327 the oil pan was more like a curve to the sump and would not clear the cross member so I traded it to a guy for one that is more like a step and it fits with plenty of clearance. I used the hooker set up.
