It is currently Thu Jul 02, 2026 7:10 am
PostPosted: Wed Mar 07, 2007 10:25 pm
I read from time to time about LUV owners swaping the Isuzu for a Toyota 22R. I had an 82 Toyota with that motor once and thought it was pretty good. Who's done this swap and what are the pros and cons?
PostPosted: Wed Mar 07, 2007 11:53 pm
The only con i can think of is that those engines (22r) are notorious for the timing chain tentioner to frequently go out causing the slack in the chain to wear a hole in the water pump line and possibly kill the engine, just like the isuzu engines.
pros, http://www.lcengineering.com :smt023
I was gonna build up the 22re in of my dads 84 celica gt-s last year but it sat too long on someone elses property so it never happened.
If its going to be a 2wd truck i would swap out the motor, 5spd tranny, and the independent rear suspension with rear discs on it. And the EFI would be a whole lot more reliable
wish i would have done that back then, but i had just rebuilt the isuzu engine and bought another 4spd
hope that helps :smt033
PostPosted: Thu Mar 08, 2007 1:23 am
I would make that swap in a second! I just missed buying a 73' with a 22R in it. :cry:
There is a ton of aftermarket go fast stuff for this engine, and they run forever!
I have had 4 Toy's and never had a engine problem.
Do make sure you swap in a 5 speed at the same time.
Looking for that special LUV.
Users browsing this forum: Google [Bot] and 34 guests
