It is currently Tue Jun 09, 2026 1:54 pm
 Post subject: Tranny
PostPosted: Sun Feb 18, 2007 7:28 pm
Got a ? bout my 700r4 in the 88 s10. I have it out now waiting to put our 400 small block back in with it. We have the kickdown to hook up but there is a white connector on the tranny for something. I just put a new stall convertor in it too. I have been told i need a switch or something to lock it up or unlock it.
Not sure it ever had one with it before. Do I need it. Didn't have one in my old 66 pu with a stock convertor.
PostPosted: Sun Feb 18, 2007 7:44 pm
Wiring is for the converter lock up . If you don't wire it it will work like a regular automatic (th-350) You have to have a stall that has a lock up clutch in it . You will need to add or fab the needed linkage for the T.V. cable or it will fry the trans . These are also sensitive to that cable being adjusted properly . Bowtieoverdrives.com is where I would look for more info.
PostPosted: Sun Feb 18, 2007 10:21 pm
we have the kickdown linkage and had it hooked up before. Just don't have the electric wire. If I remember right my convertoer I bought awile back was a non lock up
PostPosted: Mon Feb 19, 2007 9:20 am
Ok my converter is a lock up converter. Did find that out for sure.
That website is a great website. Lots of info.
