 Post subject: front disk brakes
PostPosted: Sun Jul 14, 2002 6:12 am
Im looking for info on swapping my six lug disks for five
PostPosted: Sun Jul 14, 2002 9:09 am
A lot of people are sending their rotors to Moserengineering and having them redrilled to 5-lug for $75.
PostPosted: Mon Jul 15, 2002 6:43 am
I just purchased vega rotors and had them re-drilled for 5 lug.
all you have to do after this is match up the bearings. after I do this I will post bearing part numbers.
I have had 5 lug rotors on my luv since 1994 and the rotors have spacer plates with studs in it. I will be selling these soon because of the vega rotor swap.
pictures soon.
03Cobra
PostPosted: Thu Jul 25, 2002 11:34 am
I've heard of people swapping mid 70's Monte Carlo spindles, rotors and calipers on but i dont know what it entails. The rotors looked huge. I asked the guy how it stops and he just started laughing.
PostPosted: Sat Aug 23, 2003 12:53 am
2wd chevy 1/2ton stuff is 5lug and if your running 15" rims they should just fit and youll have alot better brakes up front. I dont know exactly how hard it is to swap in but everything is doable!
PostPosted: Tue Aug 26, 2003 5:03 am
im having much trouble "matching numbers"
if I knew it would be this much trouble I wouldn't have messed with it.
I would have kept my 5 lug setup with the spacer.
ugh............. :?
03Cobra
PostPosted: Thu Aug 28, 2003 11:23 am
I sent mine to Moser, but I still have my spacers, with rotors. They haves long studs and the rotors are in good shape.
I did not like them because the pushed the wheel out. They are about 3/4 thick, I had them done by a machine shop. They are 5 on 4 3/4 pattern.
I will sell them cheap. :wink:
