It is currently Mon May 25, 2026 10:57 am
 Post subject: Steering Gear Box
PostPosted: Fri Dec 29, 2006 8:58 pm
1975 Luv steering box new, rebuild or parts to rebuild.
Maybe some information about rack and pinon for the little Luv.
PostPosted: Sat Dec 30, 2006 7:41 pm
uh your post is a bit hard to read, might want to try adding a few words in there so we can follow better. As far as rak and pinion steering, just take measurements and head to wreckinyard. With the stock box, theres a nut with a screw in the middle, loosen the nut and tighten the screw, then tighten the nut back down (wile keeping the screw steady). That should take out any play from the box. However if you are getting play in the steering, check out your tie rods and ball joints...
PostPosted: Sun Dec 31, 2006 7:42 am
here is a sample of my rack on my 78 LUV
