It is currently Mon Jun 29, 2026 10:04 pm
 Post subject: valve cover gasket
PostPosted: Thu Nov 30, 2006 11:22 pm
so after sitting for 10 years in someones elses hands i get this thing running. worked great for about a month. now it leaks oil like a son of a gun. i figured out its the valve cover. Can i just pull it off and permitex the crap out of it or do i have to get a new gasket?
Most people think of their skin as an ally. Makes me rethink having skin at all
PostPosted: Fri Dec 01, 2006 12:06 am
Replace the gasket, if it leaks and you try to patch it, it will leak again.
PostPosted: Fri Dec 01, 2006 12:19 am
Like Luvr8 said, also, don't overtighten the bolts.
PostPosted: Fri Dec 01, 2006 12:30 am
If your only leak is a valve cover, count your blessings and pony up for a gasket.
And a light film of Permatex wouldn't hurt...
PostPosted: Sat Dec 02, 2006 12:27 am
use the rubber gasket not the cork gasket
PostPosted: Sat Dec 02, 2006 8:09 am
Get the gasket, Hmmmm , I prefer the cork . Can take the cover again and if you have to and not hurt the gasket. Just don't overtork either one for sure.
