It is currently Sun Jun 28, 2026 3:05 am
 Post subject: shortie headers
PostPosted: Thu Nov 30, 2006 8:32 pm
anybody know which SBC shorties work in a '76 LUV?
i've heard the heddman s10 shorties work,any else?
 Post subject: shorty headers
PostPosted: Thu Nov 30, 2006 10:06 pm
I was talking to a guy at the dragstrip with a luv. He said that hooker headers shorties for 70 to 81 camaro small block works fine and that is what he runs and reccommended for me.
'78 Luv 1.8, soon to be 350
'69 mustang 302
'68 lemans 455
PostPosted: Fri Dec 01, 2006 5:46 am
I run Hooker super comp block huggers on mine.
 Post subject: Headers.
PostPosted: Fri Dec 01, 2006 10:49 am
So none of the shorties will be bothered by the frame or torsion bars. Will the shorties actually show much gain over a stock exhaust or the old ramhorn 2 1/2 inch exhaust
PostPosted: Fri Dec 01, 2006 12:39 pm
Short block huggers will work better than ram horns . The best performance will be long tubes . Block huggers good on a budget . The muffler shop dude will have to pay attention or you'll have clearence problems with the oil filter and starter . The pipes go above the torsion bars and torsion bar cross member . I have 2.5" pipe with removable tail pipes and 1.75" tube size.
PostPosted: Sat Dec 02, 2006 12:24 am
What are the headers that Hooher makes for the Luv swap? Are they not comp headers? or super comp?
Richard
PostPosted: Sat Dec 02, 2006 7:33 am
Correct me if i'm wrong , but I believe they are super comps.
 Post subject: super comp headers
PostPosted: Sat Dec 02, 2006 12:13 pm
Yes they are super comp. They are almost $400. They have 1 3/4 tubes and will make more power and torque than shorties.
'69 mustang 302
'68 lemans 455
PostPosted: Sun Dec 03, 2006 6:43 am
They are hooker super comps. ythey set for my 406 didnt fit too well and just werent working out right so hooker custom welded a set for mine. Now, that was back in the 90's so i dont know if they would do it anymore
79 luv drag truck
2 skidoos
2 quads
badass duramax diesel
PostPosted: Sun Dec 03, 2006 12:27 pm
Mine had a problem too. I used the Hooker mounts with the Hooker headers and the passenger side header collector flange was riding against the torsion bar. I had to slip a fence post deep into the collector and tweak the header inwards to gain some clearance. It took a while to do it cause i didn't want to damage the header.
PostPosted: Mon Dec 04, 2006 10:49 am
i am using shorty headers and custom mounts, and i had serious clearance issues! I am having to use a 90 degree angle and new collectors to make them clear the cross member and whatnot!
!!!FINALLY!!!
-1977 Luv mikado
PostPosted: Mon Dec 04, 2006 4:11 pm
I dont think a 90 degree angle would flow too well, lol. I might take some pictiures of mine for yall if you want. but If you get an exhaust kit any good exhaust shop should be able to fab you up somthing that would flow better than that. You probobly have some crazy EGT's too with it set up that way.
79 luv drag truck
2 skidoos
2 quads
PostPosted: Mon Dec 04, 2006 9:07 pm
Ezekiel duck, I've got a set of shorty headers for an s-10 lying around. They have the exhaust exiting at the rear instead of the center like a lot of shorty hearers i have seen. That may be worth looking into.
PostPosted: Mon Dec 04, 2006 9:11 pm
Wouldn't The Loop On The S10 Headers For The Steering Rod Cause A Slight Obstruction With A LUV? I'm Probally Way Wrong But Just A Thought.
PostPosted: Mon Dec 04, 2006 9:19 pm
The ones I have don't have any loops. All 4 tubes on each side come back to the rear of the engine. I don't know if they will fit a luv, I was suggesting he could see if someone local with a S-10 might have some he could look at. Sorry about the confusion.
PostPosted: Mon Dec 04, 2006 9:40 pm
My shortie headers are fine. I have home made motor mounts and I don't have any tight bends.
PostPosted: Tue Dec 05, 2006 2:09 am
well iknow that a guy on here used the s10 fenderwell headers on his luv. i havnt seen anything done with s10 shorties. im pretty sure that they would not clean the frame and probably dump right above the torsions.
now with the block huggers its not really a hard 90deg angle. its more of like flowing curve. on both of lees trucks and codys truck we used the block huggers and 2 1/2in pipe right off the headers and it flowed just fine. anthonys is im pretty sure going to be the same. unless he got different headers and didnt tell me...
PostPosted: Sun Dec 10, 2006 9:28 pm
I got block huggers on my 406. costom mounts and 8 qt hamberger pan. filter clears and starter is a mini so it clears. cross mount redid to go in front of pan so headers worked fine
http://bonsaint.com/luvalbum2/index.htm
more pics of my 76 406ci 4 spd posi.
PostPosted: Thu Jan 11, 2007 9:29 pm
both summit and jegs carry a long tube header for small block luv, i didnt like them because of how they got in the way of the spark plugs so i bought a set of 80's G body headers from headman and they fit perfect!!!
PostPosted: Sat Jan 13, 2007 12:56 am
O RLY?
you running stock type heads,automatic?
that sounds good because i would like to run LT's but don't wanna buy $400 headers for a 350hp engine
