It is currently Sun Jun 28, 2026 11:26 am
Post new topic Reply to topic  [ 24 posts ]  Go to page 1, 2  Next
 Post subject: part interchange
PostPosted: Thu Nov 02, 2006 9:54 pm
i have decided to upgrade from a 305 to a 350, but i need to know what parts i can swap over from the 305 to the 350?
PostPosted: Thu Nov 02, 2006 10:11 pm
Everything But The Block and Pistons.... You Can Use The Rods, Crank Heads, Intake Flywheel, Balancer, And Really Just About Everything Thats You Wish Too
PostPosted: Thu Nov 02, 2006 10:19 pm
thats good to here since i bought a lot of new parts for the 305. isn't the 359 internally balanced? i know my 305 has an external harmonic balancer.
PostPosted: Thu Nov 02, 2006 10:23 pm
400 Is The Only SBC That Is Externally Balanced. 305 Normally Have The Big Balancer. But ARE Still Internally Balanced.
But Yes The Only Difference Between A 305 n 350 Is The Bore and Block
( Because Of The Bore )
PostPosted: Thu Nov 02, 2006 11:46 pm
If the 305 has a one piece rear main seal, it can only work with gen II blocks. Is this correct?
From my understanding, generation I motors can be mixed matched parts to a great degree with concideration to journal sizes of the crank. 400 small block parts can go into other displacement blocks but you need to either run the 400 flexplate/flywheel and H balancer or balance the crank and rods to use the standard Chevy flexplate/flywheel and balancer.
Visit http://www.mortec.com to get some really detailed info on the parts you have or want to use.
PostPosted: Fri Nov 03, 2006 12:00 am
Gen I Can Swap W/ Gen I, And Gen II Can Swap With Gen II. They Both Are Based Off The Same Stroke, Rods, And Mains
Yeah But When You Cut Down A 400 Crank To Go Into A 350 Block You Must Still Either Use The 400 Flexplate and Balancer, or, As Already Stated, Balance It With The 350/305 Flywheel and Balancer ( I Have Personally Never Done It That Way But Have Heard Of It ) You Must Also Notch The Block For The Larger Stroke.
This By The Way Is Called A 383 Chevy Stroker Think Its A 6.3 Lt.
If You Wish To Do This I Must Say It Pays Off. I Have One In My Camaro and Even Though I Only Have 308 In The Rear It Will Move It On Pretty Good. I Can Imagen How Well It Would Do In A LUV.
PostPosted: Fri Nov 03, 2006 12:16 am
you camaro is mildy qick
Im luvin it
PostPosted: Fri Nov 03, 2006 12:18 am
It's Hauls Balls. Just Needs A Gear More Than Anything. I Am Still Hitting A Lick Running 65-70.
PostPosted: Fri Nov 03, 2006 12:20 am
i know
Im luvin it
PostPosted: Fri Nov 03, 2006 12:21 am
you need a 373 or a 411 gear
Im luvin it
PostPosted: Fri Nov 03, 2006 12:22 am
Really My Car Is't ALL That Fast But Is Fun. What You Think RedLUV80, You The Only Person Who Has Drove It But Me.
It Is Fun If Nothing Else
PostPosted: Fri Nov 03, 2006 12:24 am
it fun as hell it gets sideways easy
Im luvin it
PostPosted: Fri Nov 03, 2006 12:26 am
It's a good idea to have the rotating assembly balanced when you assemble an engine, especially when mixing and matching parts. Before everyone chimes in, I know you can get away with it, but it's still cheap insurance. My local machine shop charged $138 on my last rotating assembly. I had to take my crank, rods, pistons, rings, main bearings, 2 sets of rod bearings, flywheel, harmonic balancer. balancer retaining bolt, and flywheel mounting bolts. If you have a standard tranny, you also take the pressure plate. You can also get an adapter to put a gen I crank in a gen II block. The last few bowtie blocks I've seen came from GM that way if you wanted a two piece block. Lastly, your later gen II blocks didn't have a place for a mechanical fuel pump. That's something to keep in mind if you want to run a carb and don't want to use an electric pump.
PostPosted: Fri Nov 03, 2006 12:28 am
yea balanced it
Im luvin it
PostPosted: Fri Nov 03, 2006 12:33 am
some did you just have to drill the hole for the push rod for the fuel pump
I was n no way saying not to balance an engine... i dont care if it is bone stock as a rock id get it balanced if i could
PostPosted: Fri Nov 03, 2006 1:10 am
fuel pump rod?
Im luvin it
PostPosted: Fri Nov 03, 2006 1:20 am
yeah the rod inside the engine that goes in between a manual pump and the cam lobe
YOU KNOW WHAT IM TALKIN ABOUT REDLUV80!...lol The Push Rod for The Pump
PostPosted: Fri Nov 03, 2006 1:21 am
what are you drilling
Im luvin it
PostPosted: Fri Nov 03, 2006 1:25 am
The block on a modular engine. it has the casting for a fuel pump but u must drill the hole for the rod
PostPosted: Fri Nov 03, 2006 1:26 am
oh ok
Im luvin it
