It is currently Thu Jun 25, 2026 11:35 am
 Post subject: rear end
PostPosted: Mon Sep 04, 2006 6:19 pm
about how much HP will a ford 9 inch rear end handle?
PostPosted: Mon Sep 04, 2006 7:20 pm
Stock or with aftermarket parts axles,carrier, gears ect?
PostPosted: Mon Sep 04, 2006 10:17 pm
stock and customized...ill do whatever i have to, to make it hold up. thinkin that it wont ever have anything more than 500 hp in front of it
PostPosted: Tue Sep 05, 2006 12:52 am
Should handle that in its stride as long as its not worn out.
Bob.
PostPosted: Tue Sep 05, 2006 8:45 am
28 spline assy's are good up to around 300 h.p. 31 spline will handle more power. This all depends on the gear ratio and tire size. Plus how well the tires hook up.
For street use, stock parts will do the job. For the track, It would be best to build with stronger parts.
PostPosted: Tue Sep 05, 2006 3:15 pm
I have a 31 spline assembly with Moser axles. I have about 450 hp and leave on a 150 shot with a 10.5 tire, no problems as of yet.
Users browsing this forum: Baidu [Spider] and 40 guests
