It is currently Sun Jun 28, 2026 3:59 pm
 Post subject: internal regulator
PostPosted: Fri Aug 11, 2006 9:52 pm
Any help on converting the alternator on v-8 coversion? I'm wanting to run a one wire.
PostPosted: Wed Sep 06, 2006 10:38 am
TTT!
 Post subject: I-R alternator
PostPosted: Wed Sep 06, 2006 5:49 pm
I have gone to someone who rebuilds alternators & bought a one wire alternator for maybe 40-50 dollars. then you use the heavy gauge charging wire with a diode in line & you're done. hope that helps.
PostPosted: Wed Sep 06, 2006 8:15 pm
This might help you, it might not too, the last post has the info you want. The start of the thread is about putting an internal reg on the G-series motor.
http://www.ozgemini.com/forums/tech/viewtopic.php?t=4271
Cheers, Bob.
PostPosted: Tue Sep 12, 2006 8:35 pm
8O Why are you putting a diode in the charge wire you don't need one.You run a 10 gauge wire from the alternator to the battery hook up on the starter and you are done. All alt. have 12V hooked up full time.
PostPosted: Wed Sep 13, 2006 4:51 pm
all alt. have 12 volts hooked up all the time, but also have power from ign. switch to turn internal regulator on or off. i was told that a one wire alt. needed diode to keep current from flowing from batteryto alt. when motor is not running. otherwise it could run battery down.
PostPosted: Wed Sep 13, 2006 6:47 pm
I guess what I'm tring to do is go from external regulator to internal regulator . and still have the factory gen light work . My manual is hard to read , as it seems to have been downsized from the original . I have a GM 3-wire internal regulator alternator now and was going to buy the one wire conversion from the tractor parts dept. to make it one wire .
PostPosted: Fri Nov 10, 2006 1:31 am
O.k. I had the one wire alternator and it burnt up . I had a spare three wire for my 68 c-10 build , so I bought the plug thing to make it self excited . It is working good , but working it's ass off/feels hot . Now my gen light is on all the time . I would like to have this work like it should .
