It is currently Wed Jul 01, 2026 10:54 pm
 Post subject: front axles
PostPosted: Sat Mar 01, 2003 8:01 pm
anyone know where I can get the front axles for a 80 4x4 LUV, i went an dpicked my LUVette up today, and when i got it home, (14 hour drive roudn trip) I took it off the trailer, and notcied NO FRONT AXLES, i was never told these were not there. I sent him an e-mail in hopes he may have taken them out for some stupid reason, and forgot about it....
Any help would be appreciated
PostPosted: Sat Mar 01, 2003 8:07 pm
up where i am in cali there is a pick and pull that has a 79 luv which by the way was the donor for my header but n e ways it is 4x4 and the axle is still there. i live up in lake county if u ever heard but i hope this helps
PostPosted: Sat Mar 01, 2003 8:28 pm
do you know what they would want fot just the axle shafts? and what it would take to have them shipped to OHIO?
PostPosted: Sat Mar 01, 2003 8:34 pm
im not sure but i could call and ask him for u. but that won't be until monday but i will see what i can do for u. but i will keep u posted with what he says. matt
PostPosted: Sat Apr 05, 2003 6:00 pm
I got mine new at an O'Riley parts store for about 75$$ a piece.
but I live in TN, so I don't know if they have them in other areas.
Good luck
Power :D
PostPosted: Sat Apr 05, 2003 7:56 pm
speeking of front axles how hard is it to change the pumpkin gaskin cause mine is pretty old and i think its leaking. cause there is no oil around my oil pan seal but theres oil all over the place and i think it might be the calpret. tell me what u think and how hard it would be to do. thanx. matt
PostPosted: Sat Apr 05, 2003 8:34 pm
Resident Sparktrician
It's fairly easy if you have a solid lift and a workbench with a solid vise. Without those, I think it would be a major PITA. Getting them out can be a bitch if you need to whack on them, and you would surely need to whack on them to get them apart to install the new boots (at least I did on my old car). I hope this helps you.
Edit: We are talking about CV boots, right?
Kuranosuke
Grampa's Driving:
1990 Luv 4X4 "Family Cab"
got BOOBIES? 8O 8)
PostPosted: Sun Apr 06, 2003 12:17 am
im talkin about where the third member meets the pumkin theres like ten bolts holding it on. and i know about u joints. but is it possible to change this seal while the axle is still in the truck? thanx 4x4chevette. matt
PostPosted: Sun Apr 06, 2003 12:26 am
Sorry, not familiar with that one. The pumpkin?
Kuranosuke
Grampa's Driving:
got BOOBIES? 8O 8)
PostPosted: Sun Apr 06, 2003 1:09 pm
the housing on the axle. where that meets with the third member
 Post subject: remove third member
PostPosted: Sun Apr 06, 2003 6:23 pm
It is no harder than the rear member. Remove all the bolts ( did you say the axles are out?). Then just tap the housing with a soft hammer to break the gasket aloose. It is heavy, so don't drop it!
1980 4X4 LUV
