It is currently Fri Jun 26, 2026 9:05 am
 Post subject: 4wd conversion 2wd
PostPosted: Thu Jun 29, 2006 8:35 pm
i read the post about the conversion 4wd to 2wd? was wondering about the transfer case? i am a newbie to this ,and was thinking about buying a luv truck that i saw in the classified. it was said that you can use pup spindles off a 86 isuzu. do you need to change the drive shaft.
PostPosted: Thu Jun 29, 2006 11:58 pm
Take the driveshaft out. Instant 2wd.
PostPosted: Fri Jun 30, 2006 7:04 pm
My thought was to go with a newer 5-speed 2x2 tranny, and have a shaft built.
Looking for that special LUV.
PostPosted: Thu Jul 06, 2006 5:57 am
You shouldnt need to, the 4x4 4 speed box is the same length as the 4x2 4 and 5 speed boxes. The yolk could be different.
Bob.
