It is currently Fri Mar 29, 2024 9:18 am
 Post subject: Trans shield's
PostPosted: Tue Jul 09, 2002 3:59 pm
Thought I would throw a question out, does anyone run a trans scatter shield in their truck? I am running a Turbo 350, and would like to run a scatter shield when I swap in the new motor, but I do not know if one off the shelf will fit. If you run one did you have to do any clearancing to the tunnel to make it fit. Let me know what make/model shield you used, Thanks
LUV Truck Desserter!
76 Daily driver (SOLD)
63 Nova
74 Camaro
 Post subject: trans shield
PostPosted: Tue Jul 09, 2002 9:00 pm
You might want to try CSI trans & flexplate shield.The shield fits really tight next to your trans,that will be your best bet.They are around $275,it is a bit much but well worth it.Check the company for the thickness.If you have a 3/4 inch clearence between your floor and trans it will fit.Good luck,Michael
P.S.This shield is one piece that covers the flex and trans area.
PostPosted: Sun Jul 14, 2002 1:29 pm
HERE`S SOMETHING YOU CAN LOOK INTO.THE OLD TRANS BLANKET THEY USE TO RUN THESE YEARS AGO. I DON`T KNOW IF ANY ONE STILL MAKES THEM,OR IF NHRA STILL ACCEPTS THEM IT COULD BE WORTH A LOOK.
