It is currently Wed Jan 16, 2019 5:23 pm
Post new topic Reply to topic  [ 104 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Tue Feb 01, 2011 9:10 pm
Better ask a machine shop. I'll forward the link, and if I get and specs, I'll post them here. Gimme a couple days...
'78 1.8L 4-speed Fleetside
Image Image
PostPosted: Wed Feb 23, 2011 4:18 pm
http://www.importperformanceparts.net/i ... isuzu.html
i found this site randomly broswing google.. the 1.6 kits are totally useless to the luv... but if you decided to bore out a LUV block to fit impulse pistions the 1.9 kit would be a great option! forged pistions, copper gasket, rings, wrist pins, the timing belt wouldnt do much for ya unless you swapped to pulleys but over all i like the sound of that kit!
the 8:1 or 8.5:1 compression kits would be great if your planning on running some boost.
2002 Acura MDX the wifes daily
PostPosted: Thu Feb 24, 2011 10:43 pm
okay.... stock bore is 85mm... would i be able to bore it 2mm over to run impulse pistons or would that leave the walls too thin for a bit of boost?? i think 2mm is the equivalent of .080 over.
PostPosted: Thu Jun 02, 2011 1:14 pm
Little off the current topic but along the performance tips options....
After one has completed all of these upgrades what can we get rid of? I know I have seen several posts on this topic but I have never really seen a good answer. I think we need info in this post or make a separate sticky.
For instance I have done just about all of these upgrades, MSD, Weber, OFFY, desmogged, headers, 5 spd , Pertronix…..
Now im getting a motor (spare) back from the machine shop it’s been cleaned up bored and all of that but I want to clean up the mess in my engine compartment. Witch of the crap tons of relays and BS can I take out? So after all of this what can I get rid of….
Just wanted to know if someone had done the work already and was willing to share? Otherwise, I’m going to start doing it step by step trial and error.
Thanks
OX
PostPosted: Mon Nov 07, 2011 9:05 pm
ok so i have a 76 straight axle im pullin the motor this weekened and im gonna rebuild it were should i start im tryin to do it under 800 bucks if possible but still get some power>?? this is my first time ever rebuilding a motor tho so i dunno whats best?
PostPosted: Thu Jan 24, 2013 4:53 pm
I need an offy intake for g180?
PostPosted: Sun Jan 27, 2013 1:38 am
Hi and welcome to the forum. I sent you a message about the Offy intakes.
http://www.purerockradio.net/
PostPosted: Sun Dec 22, 2013 9:21 pm
How much horse power and torque could I get out of a 80 1.8 with a weber carb and pacesetter header ?
PostPosted: Mon Dec 23, 2013 3:19 am
The numbers would be less than you want out of it but it would have more pep than stock.
I didnt have the pacesetter but i had an electronic ignition and a weber. The weber made a noticable difference in power delivery but it was still gutless. Pacesetter would probably help a bit.
If you want to see all the ins and outs of getting power from yours check out ozgemini.com theres a 600hp turbo g180 there. Lot of 200+ hp t25/t28 turbo ones.
What kind of power are you looking for? Going to efi is more or less bolt on.. but at the same time you could get a isuzu 2.6L 4ze1 swap the intake from a 2.3 4zd1 to make it carburetted and bam more power than the 1.8 and probably cost the same a the weber and pacesetter
PostPosted: Tue Dec 24, 2013 5:37 pm
I'm looking for around 100horses and like 115 tq wanna keep the stock motor just a little mods something to the performance of my buddies Datsun 720 with a z24 there 103 horse and 130 ft lbs
PostPosted: Wed Dec 25, 2013 1:24 am
You could probably get there with weber, pacesetter, pertronix ignition upgrade and if that doesnt get you there. Delta cams cam regrind, decked head, g200 valves, offy intake manifold... ctmandu did yamaha R1 individual carbs and programmable ignition control. All kindsa options out there... g180 head on g200 block machined for g200 valves.
PostPosted: Wed Dec 25, 2013 9:46 am
Re the G200 valves: per my research the G180 head '76-'79 had 42.4mm intake valves, 34mm exhaust. The '80-'83 G180 head and all G200 heads '84-'87 had 40.4mm intake valves & the same 34mm exhaust as earlier G180 heads (Can someone confirm these numbers?).
This larger 42.4mm intake in the earlier G180 head is the same intake used in the 2.3L 4ZD1. As it turns out all G180, G200, 4ZD1 & 4ZE1 valves are very close to the same overall length and stem diameter is the same. I can't confirm there is enough head material to machine the valve seat pocket for the larger valve seats, but if there is it looks like the bigger valves would fit. 4ZD1 valves are 42.4/36mm, 4ZE1 valves are 44.2/37mm. Anyone know if this is a possibility?
PostPosted: Wed Dec 25, 2013 12:40 pm
I cant verify for sure as i havent had them in hand but the ozgemini guys that work with turbos and individual carbs use 4z valves as far as i have read into. I was going to try to go for 4z valves when i bought that impulse turbo swap. I will look into that later today and post back what i find
PostPosted: Wed Dec 25, 2013 1:42 pm
Thanks
PostPosted: Wed Apr 09, 2014 2:15 pm
Man, old thread!!
I figure I would add some info...
Anyone seen one of these?
Yep, an I Mark... It has the G200 with a 32/36 Weber, 2 1/2" exhaust and flowmaster on a modified stock exhaust manifold. No more smog stuff. It runs low 17s at the 1320 with a 5 speed.
How about this one?
This is a very rare Buick (Isuzu) Opel - 38 K original miles, 5 speed and stock G200.
I have an Offy intake (new) and several Webers, 3 sets of LUV headers (new) and various carb adapters for the G180/200.
I'll post pics soon.
PostPosted: Thu Sep 04, 2014 4:03 am
in Australia those are still popular and they are called holden Gemini's I was thinking about trying to find an imark
PostPosted: Wed Sep 10, 2014 10:14 am
Those look like a Chevy Chevette or the Pontiac version. The Chevette also had a Isuzu diesel engine option for it. '82 up came with a 5 speed transmission. I had a Chevtte when I went to tech college, it was a non interface engine. I could change the timing belt on the road side in 15 minutes. I carried a spare. Don't flame but it was a good care at the time for me.
PostPosted: Mon Jun 29, 2015 11:39 pm
Does anyone know if any of the up grade parts will work on a stock 1.8l in a 72 luv?
1972 LUV 1.8l 4 speed manual
80cc Murry Segway(moped)
1994 GMC Sonoma 4.3l
PostPosted: Tue Jun 30, 2015 9:29 am
I don't think so. The early and late G180's are a different animal.
PostPosted: Fri Jun 15, 2018 11:22 am
So for the Weber 32/36 DGEV, is that a direct bolt on to the intake? This is my first carbed vehicle. I bought it with carb issues so instead of dealing with it, I’ll just make the swap. Also does the stock carb already have eletric choke or am I going to have to wire it to something new? Thanks in advance
Users browsing this forum: Bing [Bot] and 6 guests
