It is currently Sat Jun 27, 2026 4:03 pm
PostPosted: Fri Apr 28, 2006 8:15 pm
hello all i am new to the site, but please i need some help, i have these high dollar angle plug heads to go on my 383 that going in a 77 luv that i am bulding, the only thing, left to buy is headers, the hooker V8 conversion headers summit, said they will not work, i have a lot of money in these heads and the only heads i have, could someone please tell me what kind of headers would work on the luv, a little about my truck, roll cage, 9" ford rear end, powerglide, 4-link hook up, 200 shot of nos, i am ready to put motor in when i get my headers, would regular hooker or headman long tube work that are made for angle plug heads???? thanks in adavance for any help
PostPosted: Fri Apr 28, 2006 8:18 pm
You will probably need to get a set custom made. I think this topic has come up in the past, try doing a search on this site.
PostPosted: Fri Apr 28, 2006 8:26 pm
Buy the hooker flanges and have a set fabricated, the flanges are made to work with angle plugs, I was just looking at them tonight, expect to pay upwards to $200 for the flanges though.
'76 MUD project, 1 ton axles, lockers, 20" Lift, Big Smallblock, On board air, 54" Boggers, Hummer Double beadlocks, External Rollcage... in the works.
PostPosted: Sat Apr 29, 2006 12:06 am
Maybe custom headers?
Of maybe it would be cheaper to buy the Hookers and have someone get them to work with angle plugs. My guess is that there is only a problem with 2 out of the 8 cylinders. The front two are bad news, the rest should be OK.
I think there was a thread on this already. Try the "search" feature?
I don't think block huggers will help you with this situation. They'd probably make it worse.
PostPosted: Sat Apr 29, 2006 12:08 am
I found it. Looks like it's not impossible.
http://forums.luvtruck.com/viewtopic.php?t=7671
PostPosted: Mon May 01, 2006 8:15 am
I have pictures on my website of headers I had to modify to get them to fit. Custom is the way to go.
here is 1 pic Image
03Cobra
 Post subject: Angle plug headers
PostPosted: Fri Jun 30, 2006 1:14 pm
I have angle plug heads in my 73 Luv and have some full length headers on them. I have to look up the manufacture of them when I find it I will post it, or you could email me a little later. They fit with no modification to the header. You must also remove the torsion bars.
PostPosted: Sat Jul 01, 2006 9:04 am
hooker super comp block huggers are 1 7/8 " and clear on gm fastburns. They will probably cost you power. costom big tubes would be what i suggest.
Users browsing this forum: Baidu [Spider] and 27 guests
