It is currently Mon Jun 29, 2026 2:51 am
 Post subject: Engine Upgrade
PostPosted: Tue Feb 14, 2006 12:37 pm
Will the engines out of the 81 and up LUV's and PUP's bolt into the 80?
1980 Chevrolet LUV stock 1.8L longbed
1980 Chevrolet LUV parts truck shortbed
1983 Suzuki Gs550 Sportsman
1989 Nissan King cab P/u <totalled> 4/1/06
1986 Full size Chevy P/U
1993 Volvo 850 GTL
PostPosted: Tue Feb 21, 2006 12:30 pm
I still need an answer to this question.
1993 Volvo 850 GTL
PostPosted: Tue Feb 21, 2006 1:35 pm
well as far as i know.. the isuzu 1.9, 2.3, and possibly the 2.6 4 cylinder motors will bolt right on into the luv mounts
there is TONS of info on this question.. just search!
!!!FINALLY!!!
-1977 Luv mikado
PostPosted: Tue Feb 21, 2006 10:22 pm
Thank you, thats all I needed to know.
1993 Volvo 850 GTL
PostPosted: Wed Feb 22, 2006 9:26 am
I have found a 1.9 out of a 83 PUP in my local junkyard. So I am assuming that this will bolt directly to my stock motor mounts and transmission.
1993 Volvo 850 GTL
PostPosted: Wed Feb 22, 2006 11:35 am
Banishment Pending
yup it will
 Post subject: engine swapx
PostPosted: Sun Apr 30, 2006 1:02 pm
now, on these 1.9, 2.3 and 2.6 engines, does it matter what years or the vehicles they came out of? my 1.8 is about to take a dump and I need to do a swap soon.
PostPosted: Mon May 01, 2006 2:04 am
Banishment Pending
on the 1.9 no the year doesn't matter
on the 2.3 and the 2.6 it come down to how much work you want to do, the 2.6 is fuel injected so to make it work you'd have to swap in the wireing harness and the computer aswell, or put the intake of of a 2.3 on it and have a 2.6 carb'd motor. the 2.3 was carb'd but I do know that later on, around 93-95 Isuzu did make a EFI version of the 2.3. and and one more thing with the 2.6, the 94-97 versions have some sensors that the earlier models didn't have, and i also believe they were OB-I(not 100% sure on that, 800 could clarify this for ya) If you want more info do a search for 2.6, the topic has been gone over many a time
