It is currently Sat May 09, 2026 6:33 pm
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
PostPosted: Sat Oct 15, 2011 11:31 am
oldestisuzuist wrote:
Your stock fuel pump puts out 4-7 psi, Weber says 3 max. Without a fuel pressure regulator you are probably flooding the carb excessively.
I had a Holley FPR but it leaked like crazy so I'm going to try and find a better quality unit. Thanks for the reply, I think this must be the problem.
PostPosted: Wed Nov 16, 2011 12:11 pm
Still nothing and I'm completely tapped for ideas now. FP is at 2 psi, no vacuum leaks I can find, electrical system firing. I do hear a weird gasping that sounds like it's coming from my brake master cylinder when I try to start it. That's the only strange symptom. I installed the Weber because it came so highly recommended but it has been a complete nightmare, I miss my Hitachi.
PostPosted: Tue Dec 13, 2011 1:01 am
Ok..make sure that all of your connections are tight(air,fuel, electrical). Check vacuum hoses too.Re-read your install manual or the video posted on the site. when you try to start it use carb cleaner to check for vacuum leaks while you use the throttle to keep it run(while be change in idle). Also make sure your plugs are gapped to what your Petronix manual says too.
