It is currently Wed Jul 01, 2026 2:38 am
Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
PostPosted: Fri Jul 10, 2009 7:52 am
240_jon wrote:
OK, here is what concerns me most. I know that there is a mount kit available for the buick V6, but is the 2000 Camaro the same casting? ie. Are the mounts on the same place on the block?
Idk if the mounts are the same , but mine has 155,000 on it . I bought the car new for my oldest daughter and bought it back for my youngest . Definatly a good motor . You will want to replace the plastic heater elbows while you have it out and GM makes steel elbows that install into the idler pulley assembly to use standard heater hose . Also mine is sensitive to fuel pressure .
PostPosted: Tue Jul 21, 2009 2:12 pm
If you have the Buick V6, they are the same as the earlier Buick V6's. If you have the Chevy V6 then they are different as that is a shortened SB engine. Mounts are available for it (4.3L Chevy) from www.powerbyace.com
PostPosted: Tue Jul 21, 2009 3:31 pm
Found this info :
Series II
Introduced in 1995, the Series II is quite a different engine. Although the stroke for the 3.8 L engine remained at 3.4 in (86 mm), and the bore remained at 3.8 in (97 mm), the engine architecture was vastly changed. The deck height is shorter than the Series I, reducing weight and total engine package size. This required that the piston connecting rods be shortened 1 in (25 mm), and the crankshaft was also redesigned. A new intake manifold improved breathing while a redesigned cylinder head featured larger valves and a higher compression ratio. The result was 205 hp (153 kW) and 230 lb·ft (312 N·m), better fuel economy, and 26 lb (12 kg) lighter overall weight (to 392 lb (178 kg)). The 3800 weighs only 22 lb (10.0 kg) more than the High Feature V6, despite being an all cast iron design.
The new intake manifold greatly improved breathing. To meet emissions standards, an EGR tube was placed in the intake manifold to reduce combustion temperatures. This increases fuel mileage by a substantial margin.
The 3800 Series II was on the Ward's 10 Best Engines list for 1995 through 1997
PostPosted: Tue Jul 21, 2009 8:37 pm
hotrod80 wrote:
Found this info :
Series II
Nice! I think I could find one of those really easy!
OldRob, if I am looking at that particular mount kit and I have one of the 95-97 camaro 3800, is that what I'm going to need? I just don't want to buy it and not be able to use it
Users browsing this forum: Google [Bot] and 31 guests
