It is currently Wed Jul 01, 2026 1:07 pm
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
 Post subject: Re: cracked block
PostPosted: Fri Nov 28, 2008 6:36 pm
Im not to sure what wires are which that go to the regulator on mine becuase they are taped up. All I did here was cut off all the wires at the stock alt and wired it to the '69 camaro alternator.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Sat Nov 29, 2008 1:51 pm
awsome thanks for the pic that should give me a place to start, does your gas tank needle work with that set up , as well as the "gen" light going off?
PostPosted: Sat Nov 29, 2008 2:37 pm
Yes the generator light works as if was the stock setup still, for the fuel gauge Im not sure this would make a difference. Sounds like maybe the sending unit could be bad or the gauge itself.
1975 V8 Luv
1980 Bagged Luv
Users browsing this forum: Bing [Bot] and 25 guests
