It is currently Mon May 25, 2026 12:21 pm
 Post subject: Question about fuel line
PostPosted: Wed Mar 14, 2007 9:17 pm
I was wonderin what type and size of fuel line you guys are runnin w/a fuel cell? Thanks!
PostPosted: Thu Mar 15, 2007 1:14 am
1/2 inch stainless line on the carb feed, #10 AN on the nitrous feed.
PostPosted: Thu Mar 15, 2007 10:56 pm
I think im runnin 8an lines from the fuel cell to the fuel pump. Then 1/4" into the carb. I Think?? :?
PostPosted: Fri Mar 16, 2007 6:34 am
2 -8s to the fuel filter 1 -8 to fuel pump 1/2" alum. fuel line to the fuel regulator and 2 -6s to the carb.Thats with the 800 spread bore holley but soon to have 2 AFBs set up the same way.
PostPosted: Fri Mar 16, 2007 12:10 pm
1/2 aluminum line from fuel cell to regulator and -6an to the carb.
PostPosted: Fri Mar 16, 2007 5:19 pm
1/2 inch to pump 3/8 to carb 8.5 psi
