It is currently Mon May 25, 2026 12:21 pm
 Post subject: V8 87 PUP
PostPosted: Sun Mar 11, 2007 7:27 pm
HI EVERY ONE,HAS ANY PUT A 302 SB IN 87 ISUZU OR 82 LUV IF SO ANY INFO LIKE ENGINE MOUNTS,TRANS MOUNTS OR PICS THANK U IF ANY ONE CAN HELP ME
PostPosted: Thu Mar 15, 2007 12:41 am
Most of us have done Chevys. I saw a Olds V8 in one. Several Buick V8's
BB Chevys(a whole lot of work!!!) Use the "Search" to find about one. Someone was going to put a 400m(engine type) Ford in one. I think there is a SBF too.
You can put in anything you want!! You will have to fab everything.. The stock Luv Rearend should be ok but the 4 speed trans ones has a 4:11 to 1 and the automatic has a 3:73 to 1. Serveal people with V8 luv's running the stock rearend...
Wish I was more help.. Search, and someone with moreinfo might pop in.
Good Luck with your project.
Richard
