It is currently Sun May 24, 2026 11:52 pm
PostPosted: Sun Apr 13, 2003 7:07 pm
I found this on e-bay and i have no clue what it is
This is a BRAND NEW EVAPORATOR with housing and accesories, vacuum motor,switch with wiring that are an ideal match for any early hot rod. Also included are fan spacer belt and brackets for 1976-1981 Chevy luv pickup and Isuzu Here is what it comes with it: Case bottom sub assembly; Insulation vol. 1/8 x 4 x 8 ½”; Coil, evaporator; Foam tape, ¼ x 1 x9”; Presite, 2 x 12”; Case top, w/cap tube hole; Insulation, vol. 1/8 x 4 x 8 ½”; Thermostat; Relay; Harness wire relay; Bracket, micro mtg; Solenoid; Harness wire solenoid; Door w/rod; Seal, ¼” thick; Seal, 1/8” thick; Frame;Seal, ¼” thick; Motor, vacuum; Bracket, vacuum motor mtg; Bracket, door rod retainer; Clamp, drier; Valve, expansion; Gasket, seal manifold; Bracket, manifold; Clamp, valve; Push nut, 3/16”. Manufactured by A.R.A an owners manual and installation instructions with diagrams are included The box itself is 9 1/2" wide by 11 1/2" high and from air intake to discharge is 12 1/2". The two hose fittings extend 5 " beyond the 9 1/2" width.
So leave a post about what it is or email me
lostsk8ter71684@tfo.cc
thanks kevin
PostPosted: Sun Apr 13, 2003 7:37 pm
Resident Sparktrician
It seems to be the evaporator for an aftermarket A/C system. I asked the same question in the Auction forum.
Kuranosuke
Grampa's Driving:
1990 Luv 4X4 "Family Cab"
got BOOBIES? 8O 8)
