It is currently Sun May 24, 2026 11:11 pm
PostPosted: Mon Mar 10, 2003 2:46 am
It's gettin' close to hittin' the muddy trail.....
Ok, I took some time off from the MudLuv'r but I'm back on it again.
Got the tilt frontend done. Finished the rear mounted radiator,
twin electric fans and bed mounted battery.
Got the "new" 35" tires and 15X10 Centerlines installed.
I'm still looking for a set of 36" X 15 Boggers.
You can read about the entire build-up here.
http://hometown.aol.com/danrob696/luv.html
Had a friend donate a gallon of white paint so it looks like some major sanding is in the near future.
Supposed to borrow a tubing bender and build a roll cage next weekend.
When everthing goes wrong....
What's right is what's left.
PostPosted: Mon Mar 10, 2003 3:06 am
Oh if you wanna see one of the places MudLuv'r will go after completion,
check this site out. http://themud.com
It's not just another dirty website
This guy has 44" tires 8O .........GOT MUD?
PostPosted: Mon Mar 10, 2003 4:25 am
damn man thats some good pics on that site. how big is the lift on yours
PostPosted: Mon Mar 10, 2003 12:14 pm
I'm not positive how much lift the Luv has from stock.
Probably about 10"-11".
The top of the front frame horns are 37" off the ground
PostPosted: Thu Mar 20, 2003 11:30 pm
where did you get your v8 swap kit at or how did you make it cause i am looking to lift and put a v8 in my luv. if you made it do you have any plans to make one thanks
PostPosted: Fri Mar 21, 2003 12:08 am
man, IM IN LUV with that LOVE!!! lol, ya know what i mean!!!
Josh
