It is currently Sun May 24, 2026 11:48 pm
 Post subject: putting 4.3 into LUV
PostPosted: Fri Feb 14, 2003 7:39 am
ok, is there anyway to hook a 4.3 up to the LUV 4 speed tranny?
PostPosted: Mon Feb 17, 2003 8:39 pm
dont know about the tranny, but that is my v6 of choice.
 Post subject: 4.3 v-6
PostPosted: Wed Feb 19, 2003 12:38 am
the only reason that I did not go with the 4.3Li. v-6 is because of the lack of performance parts other than GM performance. The Buick seems to have more access to after market parts.
PostPosted: Thu Feb 20, 2003 10:39 pm
if you will whant more cost efective parts (ie not just gm) i would probly go whith the 3.8 buick, theres more parts for it.
PostPosted: Thu Feb 20, 2003 11:28 pm
Yeah, but forget expense, those large tourqy jugs scream power. 8)
 Post subject: 4.3 in 4x4 luv
PostPosted: Tue Mar 18, 2003 12:38 am
This is the swap I've always wanted to do and spent alot of time thinking about it. In "theory" I think I have figured out the way to do this. First find yourself a chevy astro,(GMC safari) van w/ all wheel drive. (My wifes is a '90 and has a 4.3L in it) Pull motor and axles, (it has independent front just like the luv.) Next pick up an S-10 5-speed tranny and transfer case. I know that driveshafts would have to be fabbed and the axles would have to be shortened so this would just be a, cough....cough weekend project and a simple bolt in. :roll: Then again you could always find an S-10 blazer and bolt your luv body on it.
PostPosted: Tue Mar 18, 2003 7:19 am
I was thinking mor elike, a turbo 400 transmission bolted to the 4.3 with a divorced t-case,
