It is currently Mon May 25, 2026 12:27 pm
 Post subject: turbo luv
PostPosted: Tue May 09, 2006 10:53 pm
well my son wants to do a turbo luv so i whent and found him a impulse turbo motor with everything for $350 he will be picking it up and taking it back to texas for the conversion.... so here is my question will a G200 5 speed work on the 4zei? what ever motor, the turbo one
PostPosted: Tue May 09, 2006 10:56 pm
Well as for your question i don't know but on the other hand that is going to be one bad ass luv i hope you post lots of pics
''''Bottles are for babies''''
77 luv all original with working factory a/c
50,000 original miles
74 chevy luv 1/8th mile
bracket racer
99 chevy silverado supercharged 425hp daily driver.
PostPosted: Wed May 10, 2006 12:07 am
Banishment Pending
the Turbo motor is the 4ZC1, and I believe the G200 trans should work, you may have to mix and match flywheel/clutch to make it work, but it will bolt up to the motor
PostPosted: Wed May 10, 2006 1:50 am
It looks like the same trans in the Imp for both the G200 and the Turbo motor, but I'll have to look in more detail through my Impulse parts book. If I find any gotchas I'll let you know. If the 5Spd you are looking to use comes from a truck it might be different, but should not prevent you from getting it to work. Like rezkid said, just find the right mix of clutch parts and you'll be good. The 4Z*1 line of motors will not interchange flywheels with the G200 and G180, so clutch parts should be largely picked from the 4Z stuff, just FYI. There is two more bolts on the 4Z flywheel than the G Motors.
PostPosted: Wed May 10, 2006 9:00 am
ok thanks ... the 5 speed is from an 85 G200 motor and the turbo is from an 87 both impulses but the turbo does have the flywheel and disc on it
