It is currently Mon May 25, 2026 7:31 am
PostPosted: Thu Jan 26, 2006 11:45 pm
PostPosted: Thu Jan 26, 2006 11:49 pm
it's a little generic, but gives you a good idea of what to expect
PostPosted: Thu Jan 26, 2006 11:53 pm
PostPosted: Fri Jan 27, 2006 10:13 am
Japanese Redneck
RPOZ11 wrote:
Roadshow Bob wrote:
I liked this one:
"B/A Before/After. If the engine was installed before March of 1984, it may not need any smog controls "
this is not necessarilty true. my conversion was originally done before March 1984 and i have to have a PCV valve on my motor:)
according to a referee that i talked to, once you have the tag you can put a blower and nitrous on it and take it in for inspection as long as its still a "327 chevy" small block, its all good.
i gotta dig up my dig cam and take some pics I'll try to get a shot of the BAR tag. The BAR puts it in the door jamb of the vehicle. i hope its not a problem getting another one when i decide to have my truck painted.
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
PostPosted: Sat Jan 28, 2006 4:31 pm
PostPosted: Sat Jan 28, 2006 5:01 pm
I believe 1978 was the last year for the 400 in trucks.
Good luck
Fitzworld
A driveway full of Full size American 4x4 iron and one
LUV Diesel long bed
PostPosted: Sat Jan 28, 2006 5:39 pm
PostPosted: Sun Apr 09, 2006 3:58 pm
PostPosted: Sun Apr 09, 2006 5:40 pm
Also, you will need to be rechecked every other year just like your other cars.
I just wanted to make sure you don't take it all off and throw it away after you pass.
PostPosted: Sun Apr 09, 2006 6:01 pm
PostPosted: Mon Apr 10, 2006 11:05 pm
Japanese Redneck
RPO
DO NOT USE 882's they are prone to cracking and have the worst port design of all the 2.02 heads. Even with porting they still flow like ass compared to just about any other early head. if you want good open chamber heads try to round up some 993 heads off a target master motor. they have the heaviest casting of the later model open chamber heads in that era and will easily be ported to 170cc. I swear by these heads.
BTW have you considered late model Vortec heads? or the SR Torquer heads by world? The SR's are considered OEM replacement heads but are more performance oriented than a factory head.
for a big inch motor like what you are considering none of these heads will really flow enough for it if you run any kind of hot setup. I would consider keeping it at 406 ish displacement.
1978 LUV Truck 2WD
3.70 Ford 9
28x10 Goodyears
PostPosted: Mon Apr 10, 2006 11:17 pm
