It is currently Mon May 25, 2026 11:37 am
PostPosted: Mon Apr 03, 2006 9:19 am
A long time ago i saw on here that you can swap an isuzu pumpkin in to get better gear ratios. i searched here but cant find it anymore. Does anyone know which year isuzu and wether its a direct bolt in. All i want is to go at least 70 on the interstate and not get run over. I thought about swtiching to an s-10 rear but havent decided yet, i kinda want to keep 6 lug. Any help would be appreciated.
PostPosted: Mon Apr 03, 2006 9:49 am
http://forums.luvtruck.com/viewtopic.php?t=6160
this has some of the info you are looking for
PostPosted: Tue Apr 04, 2006 1:43 pm
if you want to stay 6 lug you could probably just switch in a toyota rear end, they have the same 4:11 gear ratio. then you can get new gears for the toyota rear end
Currently no more luv's... But in search of one!
