It is currently Mon May 25, 2026 12:20 pm
 Post subject: Qustion
PostPosted: Wed Mar 15, 2006 12:14 am
has aney one ever used one fo thes coits and are thay worth using
http://www.autopartswarehouse.com/perfo ... randid=598
my frends dodge says its eaten chevys and shiting fords well i say AT LEAST ITS EATING SOMETHIMG GOOD
________________
1978 LUV
1980 4X4 LUV
1977 LUV
PostPosted: Wed Mar 15, 2006 10:30 am
We put the Accel equivalent in the 4x4 plus 8mm wires and it runs great.
1980 shortbed Luv - 350 40 over, etc. - Like I told my momma, it ain't no fun growing up!
PostPosted: Wed Mar 15, 2006 10:48 am
The ad states that it's for an H.E.I. ignition system. And also it shows it's for a 1.8 motor. Stock motors dont have H.E.I. and this coil fits in the distributor cap. I think it's mis-labled and it should be for a Chevy V-8.
I have this exact same coil in my small block Chevy V-8. I cant tell you if it works better than stock because i've never ran a stock coil on this motor. I had a stock coil on my Buick V-6 but it's tough to try and compare the two.
PostPosted: Wed Mar 15, 2006 1:14 pm
hay one more Q
you know the copper tube that runs from the intake to the exust is that inporant besause i kinda broke it ohh can i cap it off
________________
1978 LUV
1980 4X4 LUV
1977 LUV
PostPosted: Wed Mar 15, 2006 1:44 pm
gunsonthegrill wrote:
hay one more Q
i believe that is just an EGR. i am pretty sure that it will be fine without
!!!FINALLY!!!
-1977 Luv mikado
PostPosted: Wed Mar 15, 2006 4:17 pm
Both ends will need to be capped off though.
PostPosted: Wed Mar 15, 2006 6:32 pm
thanks a lot everyone
________________
1978 LUV
1980 4X4 LUV
1977 LUV
PostPosted: Wed Mar 15, 2006 10:33 pm
oh what does that thing do aney way
________________
1978 LUV
1980 4X4 LUV
1977 LUV
PostPosted: Wed Mar 15, 2006 10:39 pm
EGR exhaust gas recirculation. It lets exhaust gas flow back into the intake air at certain times while driving. Why, I don't know. It's a smog thing. :wink:
PostPosted: Wed Mar 15, 2006 11:18 pm
Japanese Redneck
get a blaster coil and a 6AL box
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
