It is currently Mon May 25, 2026 10:49 am
 Post subject: diff
PostPosted: Tue Mar 14, 2006 7:30 am
i did not even check under the trooper limited slip, thanks. Do you know anyone who has installed the trooper LS in a 79 4x4 luv?
PostPosted: Tue Mar 14, 2006 11:26 am
Banishment Pending
Nope, I'm afraid i don't. From what I've heard unless you know what your doing with diffs it's best to just pull the third and then take it to your local shop and have them install the lsd for ya, then when their done just slap the third back in.
 Post subject: lsd
PostPosted: Tue Mar 14, 2006 3:39 pm
well, it should not be that hard, considering i rebuilt and installed one in my freinds 300zx and impulse, i was just curious if this would be a durable unit and wondering of its "manners"
PostPosted: Tue Mar 14, 2006 6:02 pm
Banishment Pending
If the impulse you worked on was a RWD one then you already know what the insides of a Isuzu 10 bolt look like, Impulse has the same center section, just modified for IRS. If you have experiece by all means do it your self. As to the lsd being durable, yes it is, the one that Calmini sells is the factory Isuzu unit, you should have no problems with it what so ever. as to it's manners, it'll handle like any lsd would, you get wheel slip on one side, the clutches will attivate and start sending power to the other wheel, pure and simple.
