It is currently Tue May 26, 2026 4:23 am
 Post subject: Frame
PostPosted: Sun Mar 05, 2006 10:21 pm
Looking for stock early 70 's rear frame rails from the torsion or cab back so i can back half my truck?
ARTIE
PostPosted: Sun Mar 05, 2006 11:01 pm
you do have a luv right so why not use the whole frame just askn :lol:
PostPosted: Mon Mar 06, 2006 6:57 pm
You are probably doing a different style of tubbin then I did, but with the stock frame rails on my LUV I did hot have the travel for the 9 inch and ladder bar set up. I had to go with a set of frame rails from summit. If you have not checked into the clearance issue, please do before you end up doing it twice. You may not need after market rails, but learn from my mistake and check. Go to the photo album area and click on Karl Ott's 74. In pic 18 you will see the stock frame set up. My problem was I had the ladder bars hitting the rails. I guess if I was running leaf springs it would have been ok.
 Post subject: Frame
PostPosted: Mon Mar 06, 2006 8:53 pm
Ok Thanks for the help
ARTIE
 Post subject: Frame
PostPosted: Tue Mar 07, 2006 8:38 am
I find it easyer to weld another set of rear frame rails inside the stock frame and then cut the old ones out.And im going to use the stock leaf springs.
ARTIE
PostPosted: Tue Mar 07, 2006 11:06 am
You should be fine on the clearance issue then.
PostPosted: Tue Mar 07, 2006 8:29 pm
Welding another set of frame rails is how i did mine and it works good.I have a 9" and ladders with axle floaters to make it work,it is narrowed 14.5"s .
 Post subject: Frame
PostPosted: Tue Mar 07, 2006 9:36 pm
Thanks for the input . I also have 9'' ford that has been narrowed.And how long does it take LuvTruck.com to post all my pictures so the whole world can check-out my first LUV
ARTIE
PostPosted: Tue Mar 07, 2006 9:39 pm
Ben's a busy guy, don't get fustrated, he'll get to it as soon as he can!
 Post subject: Re: Frame
PostPosted: Tue Mar 07, 2006 10:56 pm
Let's see the truck!
8)
72 L.U.V.
427 SBC-700R4
Mustang II front suspension
LUV perf parts manufacturing
My Devotion to Karl :
 Post subject: Frame
PostPosted: Wed Mar 08, 2006 12:21 am
The pics are on the web site now ,Click on Art Milne and let me know what you think of my stuff.
ARTIE
