It is currently Mon May 25, 2026 11:35 am
 Post subject: Cam for a 1.8
PostPosted: Fri Mar 03, 2006 10:55 pm
Please Help
I need to know where to buy a performance camshaft for my stock 1979 1.8
Thanks
PostPosted: Fri Mar 03, 2006 11:01 pm
i am looking for one my self ,if you find one let me know and if i do i will do the same
PostPosted: Fri Mar 03, 2006 11:26 pm
Banishment Pending
Crow Cams out of Aussieland make a few
and here in the States Delta Cam does custom regrinds for about $55, I personally will be going with a Delta "260" regrind.
PostPosted: Sat Mar 04, 2006 2:07 am
thanks i will look in to it
PostPosted: Sat Mar 04, 2006 2:24 am
Japanese Redneck
$55 is hard to beat but if you want a cam that really performs, call Jerry Cantrell at Schnieder cams. send him your cam (or buy a core from the junkyard). tell him what you want to do with the truck and where you want your gains, he will "cam doctor" it and then improve on that even more, weld yours up and then regrind it to whatever spec.
IMO Jerry is one of the best grinders in the country. he is one of the founders of Crower Cams (also in San D.)
You can also call and send in your core to Crower and they will do the same cept charge you a little more.
I really don't recommend buying an off the shelf grind if you are looking for the maximum gain for your setup.
anyway heres the contact info. http://schneidercams.com/
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
