It is currently Sun May 24, 2026 11:11 pm
PostPosted: Sat Mar 01, 2003 9:28 pm
Is there any other engines than the 4cy that can mount up to the stock tranny in a 81 luv.
thanks
rigel
81 LUV 4x4 Red Was a heavy hauler now is back to mostly stock config.
http://www.Rigeltech.com
PostPosted: Sat Mar 01, 2003 11:26 pm
I've heard that the early 80's Chevy 4.3 liters are somewhat easy to put in but I am not sure if you need some type of adapter.
PostPosted: Sun Mar 02, 2003 12:47 am
In theory, newer Isuzu motors should bolt up. There are 2.0 and 2.2L 4cyls. I've never tried it myself, and most people seem go V6 or V8 so there are not a lot of others doing it either. I'd take a hard look at your LUV motor and trans, then hit a couple junkyards until you find a mid-80s Isuzu Pickup or Trooper and look them over. In a perfect world, the 2.2L motor and 5Spd transmission/t-case would be a bolt in swap. That is what I've been thinking of doing, but time and funding for the project are lacking. Its hard to tear down your daily driver on "it should fit". :)
