It is currently Mon May 25, 2026 12:22 pm
PostPosted: Sun Jan 29, 2006 12:03 pm
Alrighty i was looking at the LUV diffs and the trooper diffs and they seem to be a bit diferent. I havent done anything side by side yet but heres what i think i saw...
The Trooper diffs mounts whith nothing but nuts. The axle housing has studs coming from it. On a LUV diff the first thing i noticed was the bottom two bolts. The run quite a distance through the carrier (looks like they are about 8-9" long) and also theres only 2 studs on the LUVs housing, the rest are bolts. Thats not a big deal, the big deal is those bottom two bolts. That tells me one of two things, Either a LUVs axle pinion comes in lower in the carrier or its housing is smaller. So i realy dont know what im dealing whith here anymore. :? :lol:
PostPosted: Sun Jan 29, 2006 3:21 pm
Well one thing springs to my mind, one of the bottom bolts on the LUV front diff acts as a drain plug. You are talking about the front one right?
PostPosted: Mon Jan 30, 2006 2:26 am
no im talking about the rear.
